radeon สีแดง เรื่อง 17.10.2 คนขับ support Wolfenstein 2 Assassin's และอื่นๆอีกมากมาย!
  • radeon สีแดง เรื่อง 17.10.2 คนขับ support Wolfenstein 2 Assassin's และอื่นๆอีกมากมาย!
    the new radeon สีแดง the เรื่อง 17.10.2 คนขับ with support Wolfenstein 2, Assassin's Creed, Destiny 2 และอื่นๆอีก มากมาย!
    http://support.amd.com/en-us/kb-arti...?sf124626222=1
    หมายถึง ไดรเวอร์ใช่มะ
      Radeon? Software Crimson ReLive Edition 17.10.2 Release Notes
      Article Number: RN-WIN-RADEONCRIMSONRELIVE-17.10.2
      Radeon? Software Crimson ReLive Edition is AMD's advanced graphics software for enabling high-performance gaming and engaging VR experiences. Create, capture, and share your remarkable moments. Effortlessly boost performance and efficiency. Experience Radeon Software with industry-leading user satisfaction, rigorously-tested stability, comprehensive certification, and more.
      Radeon Software Crimson ReLive Edition 17.10.2 Highlights
      Support For
      Windows?10 Fall Creators Update
      This release provides initial support for the Windows?10 Fall Creators Update. For more information please visit here.
      Wolfenstein? II: The New Colossus
      Up to 8% faster performance on Radeon? RX Vega56 (8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.1 at 2560x1440. (RS-188)
      Up to 4% faster performance on Radeon RX 580 (8GB) graphics card than with Radeon Software Crimson ReLive Edition 17.10.1 at 2560x1440. (RS-189)
      Destiny 2?
      Up to 43% faster performance on Radeon? RX Vega56 (8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.1 at 2560x1440.(RS-184)
      Up to 50% faster performance on Radeon RX 580 (8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.1 at 2560x1440.(RS-185)
      Assassin's Creed?: Origins
      Up to 16% faster performance on Radeon? RX Vega56 (8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.1 at 2560x1440.(RS-186)
      Up to 13% faster performance on Radeon RX 580(8GB) graphics than with Radeon Software Crimson ReLive Edition 17.10.1 at 1920x1080. (RS-187)
      GPU Workload
      A new toggle in Radeon Settings that can be found under the "Gaming", "Global Settings" options. This toggle will allow you to switch optimization between graphics or compute workloads on select Radeon RX 500, Radeon RX 400, Radeon R9 390, Radeon R9 380, Radeon R9 290 and Radeon R9 285 series graphics products.
      Compute Support
      Radeon Software now supports compute workloads for up to 12 installed Radeon RX 400, Radeon RX 500 or Radeon RX Vega series graphics products on Windows?10 system configurations.
      Fixed Issues
      Radeon Software may not appear in the uninstall options under "Apps and Features" on Windows? operating systems after a Radeon Software upgrade.
      Minor corruption may appear in PLAYERUNKNOWN'S BATTLEGROUNDS? in some game locations when using Ultra graphics settings in game.
      Radeon Wattman may fail to apply user adjusted voltage values on certain configurations.
      AMD XConnect? Technology enabled system configurations may not be detected when plugged in or connected to a system after being previously unplugged during system sleep or hibernation.
      Hearts of Iron? IV may experience a crash or system hang during some scenario gameplay.
      Radeon Settings gaming tab may not automatically populate games detected on the users system.
        ในบางเกม
          ตานี้เค้าก็สงสัยเหมือนกันว่ามันได้ขนาดนั้นจริงไหม
            เมพ ขิงๆ
              แรง 3 เท่า อีกปะ
                Compute Support
                  จอหายมืดยังนี่
                  ลง 17.40 มา จอเข้มมาเลย
                    - - - Updated - - -
                    Originally posted by Hirasawa View Post
                    จอหายมืดยังนี่
                    ไม่รู้นะ ของผมดูปรกติ ไม่ออก
                      อือครับ คงต้องกลับไปลองครับ
                      ตอนนี้ใช้ 17.7 จาก windows update อยู่ ทนใช้ 17.40 ไม่ไหว
                        มาแล้ว driver ในอนาคต จิ๊กซอว์สำคัญ อิอิ รอดูก่อน เผื่อช้อนซื้อ 480 ซัก 10ตัว
                          ไม่มีข้อมูลไอ้ compute mode , graphic mode , power efficiency เลยแฮะ ไม่มี raja มาพล่ามละ...
                          แต่ driver นี้ shadow of war แรงขึ้นนิดหน่อยด้วยเย็นลงอีกนิดหน่อย
                          ละไอ้ compute mode 12 card นั่นคงต้องรอคนเหมืองลอง....
                            ถ้าหาเจอก็มี ถ้าหาไม่เจอ ก็เหมือน ม่ายๆๆ มี
                              แร้ง แรง กราฟเทพ
